Iamjohnhayes wrote:i believe only e manage ultimate allows you to eliminate the maf which is good if you have your setup finalized. B/c as far as i know if you go map only you have to retune if you decide to up the turbo boost or change a cam, or any work to that nature.
A correctly built MAP system does NOT require retuning every time you change boost or anything else. The problem is that many people who convert from MAF to MAP fail to add an IAT (Intake Air Temp) sensor, nor does their programming method provide the factoring information for the IAT. The only way to correctly calculate air density using a MAP is to also use IAT. Without the IAT variable, the MAP means nothing as to the amount of air molecules present at a given absolute pressure.
If your car is equipped with a MAF and you must run open BOV, I would recommend this:
Run the MAF on the cold pipe as a blow-thru setup. Not only does this give better throttle response and allow the open BOV, but it also gives a much more accurate reading of the air going into the engine. This will provide for a much more efficient tune.
Mount the BOV on the hot pipe. Now, when the BOV opens, the amount of air flowing backward through the MAF is minimal and there's virtually no air being purged that was already metered.
