DRIFTEADOR wrote:thats not true; the car rides on air. at the same tire pressure the contact patch will be the same area but a different shape for different size tires . with a wider tire the pattern is short and wide, good for lateral grip/handling, and with a narrower tire its longer but narrow, not sure theres any adantages there except ride quality. the wider tire will of course wear slower, but how does it make for more traction?
and btw, do any of you guys use bfg dr's. imo, nitto's suck, g-force t/a is the stickiest radial tire i've used.
This guy is the win. A contact patch, according to Skip Barber Racing School, "has the approximate area of a postage card. When using a wider tire, the length increases, but width decreases." As he said, it makes more lateral grip. Which means more straight line traction. But.. it also gives more surface area exposed to the air to cool down the tires, making them hard to heat up and keep heated. There is a tire too large for an application.Nittos are good tires imo. I had NT555s, not bad at all for street.
I run a 18x10" in the rear with Goodyear Eagle F1 GS Fioranos (whew.. mouthfull) in 265/40/18. My nittos were 35 series and were 1.6% larger than stock.. these new ones are ~6% larger.. but $200 for the brand new pair of $700 tires. 18x8" up front with 225/40/18 Nitto NT555s. Haven't used drag radials in ~6 years, so I'm way behind the times with the new ones.-Jeff
