how wide in front?
ross6200
Car: 2007 Infiniti M35x
After reading through a bunch of posts, I have determined that with my wheel upgrade, I do NOT want to go staggered on my 2007 M35X. I don't like the look, and also don't want to do anything to mess up the AWD on the car. I want to keep things even all the way around, and I'd like to go with a 19x9.5" concave wheel. Shouldn't be an issue for the rear, but how about the front? I know most people go with 8.5 up front, but I see some have gone wider. If I go 19x9.5 up front, what offset should I have? Are there issues with rubbing while turning or with the fender?
I should mention that my car is lowered with the Espilir springs (made for the X), which is roughly a 1.5" drop.
Thanks for any advice /suggestions!
06M4.5
Car: 2006 M45
I would do 40-42 offset
and upgrade to 20's
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Shouldn't have any problems at all... With a 9.5" wide wheel!! Offset you are looking at 38-45 no more than that...maybe +35 with the right tires! Good luck! :bigthumb:
ross6200
So, I decided on a Lorenzo WL197 in 20x9 inches all around. These should definitely fit flush with no clearance issues. They don't come in 20x9.5....so all's good! I get them put on this week, Finally, because the stocks have been boring me. I'll be putting them up for sale:
18x8 chromes from 2003-04 M45
The Bodyguard
Definitely no clearance issues with that size 20" what size tire you going to run? Not sure yet? I would recommend 255/35/20 the added width for a square set up is nice, wheel wells in the M is big!! Nice looking wheel, :dblthumb:
ross6200
I'm going 245-35-20. Thanks for the thumbs up! Can't wait to see how they look on my M!
The Bodyguard
ross6200 wrote:I'm going 245-35-20. Thanks for the thumbs up! Can't wait to see how they look on my M!
This size may look a bit on the small side but you could only tell until it's done :gotme with the drop you have it may be fine!!
