how well will these Enkei mesh fit???
VinceSez
Car: 1992 Nissan 240sx
Like the topic says, how well would a set of Enkei mesh 15x7, with three wheels having an offset of 1+ and another wheel having 0 fit on my stock 240sx fb? will the wheels stick out? what would i need to make it look flush? im not sure of the lug pattern, but im going to find out today.
continental_drift
Car: 1991 Nissan 240SX coupe - in progress - zeal function V6, ssr formula reverse, trust SP. more to come.
make sure of the bolt pattern before you go any further. then, source another enkei mesh in either +1 or 0 offset, there is no point in running 3 wheels that are the sameand 1 different... 1mm is a pretty nominal amount but still...
they should fit alright, and it should not be difficult to find pictures of s13's with 0et enkei mesh. just use the searchfunction. just so you know, the rears will most likely nottuck unless you do a minor fender lip roll.
I'm running 15x7.5 -5et in the rear, look for pictures of mycar if you want to see how much it sticks out.
my 15x8 +14 fronts fit completely flush.
