boost - buy a vacuum splitter and place it in the vaccum line that is going from your throttle body to your FPR.
oil press. - the threading on the sender is probably 1/8 NPT. However, the SR block is a 1/8 BPST. Therefore you will need a 1/8 Male BSPT to 1/8 Female NPT adaptor. You can find this adapter from Mcmaster-carr. Do a search on their website for part# 4092K11. Just remove the stock oil pressure sensor and leave it unplugged. It will no longer be necessary since you will have your gauge monitoring your oil pressure.
water temp - Order yourself a water temp adaptor that goes in your upper radiator hose. Something like this
http://www.sr20forum.com/revie...ct/59. Or you can try and tap your stock upper radiator neck with a 1/8NPT if you the correct tap.
A/F Ratio gauge - Throw it in the trash because its useless unless it is a real wideband o2 sensor.
