How to wire altima electic fans in S14
fame_s13
Car: 1997 S14 KOUKI
2008 SCION tC
hello,
i just bought my first 240sx its 97' s14 and i wanted to do the electric fan conversion.
i have been looking at the diy's on nico and i want to run my fans automatic when the temperature reaches 170*
so i read this DIY: how-to-wire-up-an-e-fan-the-really-wasy ... 42522.html
and this is for an s13.
So i started looking for a coolant sensor but im not sure which one to get and i can't find the one that this guy used.
i found that AEM sells a kit for sensor but its not adjustable which can be set to 170*
also looked at summit racing and they sell the kits which would not alow me to run AC. so i am wondering where i can get a sensor that was used in the DIY link i provided.
I'm looking to do this today so help would be very appreciated.
and if anyone has any idea to wire them w/o a switch inside to turn on the fans please let me know please.
thank you
Hoffman5982
Car: '95 sr20det 240sx
I went to napa and got one. Ask for a thermostatic switch. It's made by Derale, and it has worked fine for me, except I just ripped the radiator probe out so I have to get another one. It costs like 30 bucks.
You'll also need a relay(atleast if you wanna do it right)
fame_s13
Car: 1997 S14 KOUKI
2008 SCION tC
^ thanks for replying.
so i looked online about the thermostatic switch and found this http://www.summitracing.com/parts/HDA-3653
so my question is now can i use this in the diy link i provided and how does the sensor hook up?
could u tell me how u wired ur electric fans? that would be great!
thanks
fame_s13
Car: 1997 S14 KOUKI
2008 SCION tC
also i found this made my Derale: http://www.summitracing.com/parts/DER-13021/
but would this work for dual fans? and where would i tap this?
thanks
Hoffman5982
The link to summit racing is pretty much the exact same thing. You're looking to run both fans off this? My bad. I have one of my fans hooked up to the original plug for the single fan, and the 2nd fan wire to the thermostatic switch. Give me a minute so I can sketch up a diagram in paint
Hoffman5982
Ok here you go. The controller is the Derale thermo switch. There's 2 poles labled 2 and C. If I had the instructions I'd be able to tell you what each one does in case you get one that isn't labled the same. Hope this helps!
fame_s13
Car: 1997 S14 KOUKI
2008 SCION tC
Hoffman5982 wrote:The link to summit racing is pretty much the exact same thing. You're looking to run both fans off this? My bad. I have one of my fans hooked up to the original plug for the single fan, and the 2nd fan wire to the thermostatic switch. Give me a minute so I can sketch up a diagram in paint
Actually if i want to run my ac, i would have to run 1 of fan w/ the stock ac fan harness..and then wire the 2nd fan to the controller (also i am guessing u r refering to the first link of hyden controler? which is this one : http://www.summitracing.com/parts/HDA-3653 )
and do u know how the radiator probe is hooked up?
thanks for the diagrams..helps alot!!
Hoffman5982
Yes, that's how Im running mine. And that hyden controller looks exactly like my Derale one, I just don't know if the poles are labled "2" and "C", which isn't a big deal if it isn't. But you might as well go to autozone and get one so that you don't have to wait for shipping, but that's up to you.
The probe just sticks into the radiator fins. It's bind a couple, but that won't hurt it. I can't remember if it told me exactly where to put it on the radiator(I hooked it up about a year ago), but I had mine at the top left corner when standing in front of the car looking back. I'm sure it has to be near the inlet. I mounted the controller behind the passenger headlight. Ill find the pics later if I have them
fame_s13
Car: 1997 S14 KOUKI
2008 SCION tC
ok that sounds great...i went to autozone today but they did'nt had a thermo switch..ill try napa or carquest tom.
and pics of where u mounted the probe would be awesome!
thanks hoffman..really appreciate it! :)
Hoffman5982
Yea I got mine at Napa. They had to order, but I picked it up the next day. This is the only pic I could find. You can see it behind the passenger headlight
And here's the controller with the poles labled incase whichever one you get isn't labled the same
fame_s13
Car: 1997 S14 KOUKI
2008 SCION tC
pics help alot...thanks alot
im gonna go get it from napa tom. and if i have questions ill post here!
thanks alot!
Hoffman5982
No problem
fame_s13
Car: 1997 S14 KOUKI
2008 SCION tC
ok so i got everything hooked up but now im wondering where to get the ignition +12Volt that i can use on my relay? any suggestions?? wat source would be the easiest one?
also the relay i got from Car Quest has different side prongs like 86, 87, 85, 30...they r on opposite sides then one in Hoffman5982's diagram?
thanks
