I drilled through behind the glove box (fit my 1/0 AWG cable fine):FredX wrote:hey all, ive searched with no luck and my question is how to get the power cable to a subwoofer through the firewall with a 6 speed transmission. i know with the cvt a hole can be drilled but thats where the clutch is so i am left clueless. anyone have suggestions or know of more places to drill??
If you pull the glove box out and look behind the carpet you'll see this location. It looks like there is almost an indentation in the firewall (where they were going to put a rubber boot or something but didn't). You can probably also see it from the engine well if you look back in that area. When you find it, you'll notice that you can easily drill through without hitting anything vital. I was worried about drilling at first, but once I found this spot I was a bit more confident. I put a 1" drill bit right through there with no issues. If you do this, make sure to use a rubber grommet to protect the power cable from sharp sheet metal.FredX wrote:thanks! i remember seeing a place where you could drill but i didnt think it was behind the glove box, i thought it was lower, like actually visible if you just leaned over. was there any problem there with drilling into the engine compartment with all the stuff there jsut waiting to be destroyed? lol i finally get my car (after about 6 weeks of waiting) tomorrow and im so excited to put my new sub into it!
Didn't even notice that. But, it's no longer the case now.FredX wrote:hopefully your last post being your 666 post wont jynx me in drilling into my brand new engine : lol
