*** This thread is NOT for tips or guidance on restoration. This thread is for vehicles that have a stable and new or very well maintained clear coat layer. If your vehicle needs restorative work, I suggest using
http://www.google.com to find out how to repair your finish.***
In this thread:
- Overall Advice
- Summary of Steps
- Steps on Rinsing and Drying
- Steps on using Compound
- Steps on waxing
- Steps on buffing
- Steps on finish-up
- Final advice and guidance
Overall Advice
My experience with Meguiars is what Im satisfied with and what I recommend to people. Of course, detailing, in and of itself, is specific to the detailer. Everyone has their trends, methods, product favorites, and styles that they use when they detail. Ive had nothing but superb performance with Meguiars myself, but you might be different. Try different products out and see what you like best
A wax is designed to be a sacrificial barrier between your cars paint and the outside atmosphere. Wax is essential for protecting your cars finish from clear coat failure and eventual paint failure. Proper care and time is necessary to be invested into your cars coat so it lasts, is protected, and shines like its new.
My car has original paint from
Chrysler...not the highest quality or effort a company can provide for their cars. Although not perfect, wax has produced these results on this 13 year old daily driver:
Summary of Steps to Take
So heres how I do this. Follow these steps below and you can have a brilliant finish, regardless of the make or model (or even paint color...*cough gloss black cough*) of what you drive.
1. Rinse and dry off vehicle in accordance with Step 1 and 2 in this thread
how-to-wash-dry-detail-your-ride-t502848.html
2. Apply and remove Meguiars Ultimate Compound
3. Apply and remove Meguiars Next Generation Tech Wax
4. Rinse and dry off vehicle again.
5. Maintain by keeping the car clean and following Steps 1 through 4.
Step 1. Rinse and Dry
Follow the Steps
RINSE AND DRY in this thread
Step 2. The Compound
If you have a finish that has been abused and neglected, this product can be applied by hand or by orbital to restore the finish, revitalize color, and eliminate swirlies and slight scratches. This compound makes restoration very easy. It also gives your cars paint a good foundation to apply wax over.
Price: $9.99 Classification: Clean and Prep
^ By reading this, you understand that Meg's UC can be applied like a wax. And then buffed off. Do this as described by using a clean micro-fiber towel and you will see instant results. Apply UC in sections. Allowing each section to dry thoroughly.
Step 3. The Wax
- Meguiars Next Generation Tech Wax 2.0: This is the best liquid wax I have ever used. Its results give you a deep color rich look, the best water beading, oxidation, corrosion, UV protection, and shine and gloss appeal. It can be applied by hand, orbital or DA polisher.
Price: $17.99 Classification: Wax NXT Generation.
^ This wax is expensive. However, the results speak for themselves*. When you apply and remove Meguiars Ultimate Compound and then immediately do a follow-up wax application of this Tech Wax, your results will truly be amazing. It makes your color deeper and more vibrant, it makes your paint SHINEY, and it also protects against UV rays and other various forms of contaminants. This wax is recommended for application and removal with a clean micro-fiber towel. Apply Megs TW2.0 in sections and allow the wax to dry completely.
* Meguiars Next Generation Tech Wax can be applied to all vehicle windows. In fact I highly encourage you to wax your windows. The water beading effect of a waxed window is not only a safety consideration (since the water beads up and rolls off your glass) but it also helps keep more components of your car clean by not allowing water to build-up and bake off, leaving water spots.
Step 3. Rinse, Dry and Detail
Follow the Steps in this thread
Step 4. Maintain
The Maintenance Phase is the most important factor of detailing. What good is that coat of wax you just spent 3 hours applying if you let it sit neglected for the next 7 months? Take care of your car by cleaning and maintaining it. The rewards will speak for themselves. Maintaining is going to be easier for some of you than others. If your schedule or finances dont allow you the time and effort, then do as best as you can with what youve got to keep your car clean.
