I used to be a hardcore Zaino fan, but their exterior polish products are time consuming to apply. Although, it works great, but I saw one product that could do the same in less time. I forgot that brand, I`ll look for it. No, I`m not affiliated to Zaino :-) No comission here.
I think it`s ULTIMA . But if you have all the time in the world , Zaino polish is the way to go. You can do multiple coatings , 3 coatings recommended to last fo 12 months.
if you go Zaino way. This is my routine every summer.
1) Wash the car with "JOY" dishwashing liquid to strip the wax that currently on the paint. (Mix a few oz of JOY with Gallons of water in the bucket)
Hand wash it.
2) Rinse
3) Wipe the car dry
4)Use this : Meguires Smooth Surface® Clay Kit (Cheaper at Walmart $13) or Zaino Clay bar.
5) Then I use Zaino Z6 to remove left over spray from the clay bar kit.
http://www.zainostore.com/Merchant2/mer ... ct_Count=9
6) I mix
http://www.zainostore.com/Merchant2/mer ... _Count=196)
and
http://www.zainostore.com/Merchant2/mer ... ct_Count=6
Using the ZFX will cure the polish faster and the next coat of polish can be applied after half hour instead of few hours if you don`t use this.
7) You apply the polish or Z2 mix in the bottle with ZFX. Then apply it on the car`s paint surface. Let it haze and wait for half hour then do minor buffing.
8) Apply another coat of Z2 and another one and another one, as many as you like with half hour interval per layer, but do minor buffing and let it haze first before buffing.
9) You can use this
to seal every other coating and the last coating. You can also use this Z6for everyday maintenance to wipe of dust etc....
10) Have a good long rest and grab a can of beers. Make sure you don`t work the next day or possibly don`t drive as your whole back and arm are numb and achy the next day.
For the wheels this is what I use to protect it.
http://armorall.com/products/view_produ ... ndex=wheel
