RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Sun Nov 07, 2010 11:01 am
Normally when those bushings go out they become noisy especially when driving over uneven areas when turning the wheel where it puts a stress on the chassis. If you aren't experiencing any of those noises, pass on the bushings. Inside tire wear, also referred to as feathering is caused by alignment issues. The toe needs to be set to max toe in on these cars to help with that issue, but will never completely cure the problem as it will always be an issue for g35/37 chassis.
