tools:
-PB Blaster
-BFH
-flat tipped chisel
- anti seize
-17,14 socket. 19 wrench
1. soaked the living crap out of the tread in PB blaster and let it sit for a day.
2.take the coilover off the car.
3. turn it upside down and spray in the thread of the bracket and let it soak.
4. place the chisel in the collar and beat the s*** out of it.
5. set the coilover on the ground and place the chisel on the weld for the brake line bracket.
6. this would be the step where i plan to completely disassemble the coilover and repaint everything. but its under 30 degrees out so that will wait until summer.
7. use a lot of anti seize
8. slam it
9. repeat 3 more times!
no pictures of it installed slammed because i either have to tub it or get smaller tires. it was hitting the inner metal. so i had to raise it back to where it was but whatever its unseized.
