jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Wed Sep 27, 2006 8:41 am
TEIN S-TECH Springs lower it about 1.2 in the back, and 0.8 in the front (it might be the other way around). the ride is really soft during cruising and these are affordable springs.
if you plan on getting stock springs (or aftermarket), try looking for a used set that already has them installed with the shock so its plug and play for you. unless you have access to a spring compressor, that works as well. u can use the hook type compressors from autozone (they hook each coil).
