how to turn off the engine service light
qdao
I have a 2001 QX4 and the engine service light led up, how can I reset this service light or I have to go to the dealer and pony up $100-$150 to reset. Thanks.
NISTECH
Something is wrong with the emissions system. That is why the light is on. You can run to autozone and they will pull the codes for free usually.
qdao
Thanks NISTECH and I will keep you update.
Jack1944
Check your gas cap...
94q45t
Car: 94 Q45T (wrecked), 94 Q45 (healthy), 00 Suburban, 87 Supra mkIII, 98 F150 4wd,
The Davis Car Chip can reset the light. It costs $125 which is expensive if this is all you want to do. If you don't fix the underlying problem, the light will re-appear in about 100-150 miles. If you do fix the problem, the light will go out on its own in about 200 miles.
NISTECH
The light will go out after 2 good tests and after 2 warm up cycles. which ever occurs later. There is no mileage when it happens. The car has to be started cold and warm up to operating temp twice as well as perform at least 2 consecutive passing self tests before it will turn the light off.
qdao
Everyone,
I went to the dealer today and they diagnosed the back O2 sensor was defective, and it cost $184 for part and $250 for lalor. Thank you everyone for your help.
Jack1944
I bought one of these readers...$100.00 from Kraegen...Works on all cars...And will also turn off SES lights...
INNOVA 3100Digital OBD II Code Reader
http://www.troublecodes.net/ar...shtml
