Razi »
https://forums.nicoclub.com/razi-u53191.html
Fri Apr 24, 2009 7:01 pm
Hello and welcome!Do all the normal maintenance things, like new spark plugs, wires, etc...Should get you a little more horsepower.
As for making 180 hp on NA, it could be very difficult to make that much as NA on the KA24 engine.Most people turbocharge their engines to make 200-ish hp.My car is my daily driver and has a turbocharged KA.
To make your steering rack a true manual steering rack, you should disassemble it and remove the middle seal and then loosen up the spring inside the rack, which I heard gives you more of a real manual steering feel.But most people just loop their power steering hoses.And of course you need to remove the PS pump.Removing PS might net you a little bit more power but probably not a noticeable amount.
