cr4west »
https://forums.nicoclub.com/cr4west-u145518.html
Thu Mar 05, 2015 12:53 am
At 200k I am still running all original cats and all 4 o2 sensors and just passed a smog check. Other repairs were front rotors, 5 sets of auto zone ceramic life time guarantee brake pads, front hub bearings and outer CV boots, steering rack, mounting bushings and steering pump, front lower ball joints, front and rear struts, alternator pto bearing, internal regulator and set of 50A diodes, transmission oil, pan gasket and filter (done at 75k and again at 180k), 3 sets of tires, valve cover gaskets, tail gate struts, tailgate hinge, many light bulbs, tie rod ends, evap charcoal canister, AC compressor clutch bearing. front engine crank shaft oil seal (done at 75k and again at 180k), All the repairs I did myself thanks to this site. Cost was parts alone.
