180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Nov 06, 2006 11:34 pm
reverse plug is at your transmission harness, not the ecu harness that the guys at wiring specialties will do.
Your mafs not working, check to make sure you've first got continuity across the harness to the mafs. Next make sure the plugs are actually making contact with the mafs, it might be a good idea at this point to make sure you don't have alot of gunk on the plugs that will screw up the connection between the plug and the mafs. post back what you get.
do you have anything else sitting between the mafs and the ecu like perhaps an afc?
