mac,one tip I giving for the "Idea" of multimeter testing (I don't know car & not condoning this strategy one way or another). Has to do with the peculiar aspect of ANY Hi-Voltage "situations" , always dangerous epecially if fooling with "Mains" sourced energy!
Tip - a coil testing OK on ohms , continuity etc. IF there is ANY internal Hi-V potential for shorting , or worse the "intermittant shorting-internally" CAN BE A VERY FRUSTRATING situation you THINK you've cleared as OK - if your not aware of this scenario, one may go "nuts"& possibly never or after considerable time (wasted) realize that said Hi-Voltage device/ part/wiring whatever- IS Ok when not!
This is what the term "burn-in" has to do with subjecting electronic equipment to ACTUAL WORKING CONDITIONS & SCENARIO .
If coils are to be tested "hooked up & layed out" on top of manifold to SEE that a regular occuring spark , no "skipped beats", IS ACTUALLY SPARKING,one thing - you MUST ground the metal "frame" of the coil using jumper to manifold or block. That way you don't OPEN UP a "WAY" or "compromise" the insulation whereas a carbon-track can buildup and NOW YOU have created a fault to grow from intermittant short to all out "100% Dead Short"
Also you NEED to put like a phillips screwdriver INTO the end of the "boot" all the way touching the "contact spring" inside, leaving a gap to block or manifold no more than 1/2" so spark doesn't also compromise the internal insulation.
