Yes there is a rear one ... just in front of the fuel tank. Not hardto replace except that you'll need to get underneath the car.
I finally broke down and just pulled the pump out ... then it's easy to test with a couple of alligator clipped wires at the battery.The hardest part of getting the pump out is dealling with the fuel lines that connect to it. I used a combo of taped up pliers and a flat bladed screwdriver to work them off. There's a big 4 inch dia O ring under the plate that the pump is mounted to ... make sure you have that in place correctly when you put it back in.
New pump at Autozone cost me $99. The old pump was frozen.
This site is the best for pics and instruction on the procedure ...
http://sr20.hybrids.jp/install...pump/
Good luck!
