How to Test Coilpacks for SR???
clutch Kick drifter
Car: 1992 Nissan 240sx/ Blacktop SR20det
How can i test out my coilpacks on my SR?>
s13sr20chris
check for power ground and signal.
THE MARKS ON THE COILPACKS MEAN NOTHING!
you should have 12v, ground, and a pulse signal. you will need a good multimeter to test the signal. the coilpacks are marked with a +, -, and e. those do not mean 12v, ground, and signal respectively. rather they will be mixed up. get me? i have been through this on 3 cars with supposed coilpack problems. all three were bad wiring at the ecm killing the signal.
clutch Kick drifter
oh ok... so i just put it into the coilpack and it shoudl read ...... what ?
s13sr20chris
you can test the resistance across any two terminals of the coilpack. that gives you a total of 3 possible combinations. i dont know the specs but i can tell you this. the chances of you having 4 bad coil packs is pretty slim. check all of them and as long as they are all the same you are good to go. thats all i can tell you without specs.
