Cyberkreig wrote:Generaly speaking, No you cant identify the year of your motor. It is really only possible to identify a range of years.
If the motor has a red valvecover its a 1991 - 1993.If the motor hasa black valvecover is between 1994 - 1998.
Motors made between 1996 - 1998 are often refered to as the "type -x" motor. They need the J7 ECU.
Thats about the best you are going to get.
90.5-92 1st gen redtops (NO HEATSYNC CAM FINS)93-94 2nd gen redtops (heatsync cam fins)95-99 3rd gen blacktops (heatsync cam fins)chickentendah wrote:Within the 1991-1993 years, you can narrow down the year by looking for heat-sink fins on the head.
Don't quote me on this, but I believe that within 91-93, only the 93 had the heatsink fins.
Modified by chickentendah at 6:17 PM 10/5/2004
DJ,this is cool but how do you differentiate an early s13 blacktop from a later s13 blacktop. There are differences but no easy way to distinguish without the ecu.dj_lennon_franz wrote:
There is not a vin on the block. i found some #s on the block but no vin #s.Altiman94 wrote:couldnt you check the vin on the block with the manufacturer to see when it was built? Im sure thats all recorded somewhere
Yup, Hes RIGHT!!Cyberkreig wrote:Generaly speaking, No you cant identify the year of your motor. It is really only possible to identify a range of years.
E5 is a manual ECU. E6 is an auto ECU. J4 (ITS J4 PEOPLE, NOT J7) is a manual ECU. The difference between auto and manual ECU's is that auto's will have higher idles, say +800 RPM's while moving. (unless you still have an auto TPS). The E5/E6 ECU is not immediately interchangable with the J4 ECU. You have to repin the ECU's. If you used a J4 ECU on a redtop or early model blacktop, it will only fire on the 1st cylinder.blackbeltclub99 wrote:Are these interchangable? I mean are all the blacktop ones pretty much the same? Are the E5, E6 and J7 all auto's or 5sp's or were there different versions of each? If so anyone know the difference in an auto and manuel ecu? Is it the other numbers?
Unfortunately I deleted a pic of exactly that I had about a month ago. If I remember correctly it was one of the unused plugs found on the igniter chip plate. It may have been this plug in the picture, but obviously if the ApexI plug doesnt fit into this one, then its one of the other plugs nearby.180crafter wrote:Hey speed racer!!
Go any pics of the plugs that control boost. I need to hook up my power FC's boost controller and have no friggen idea where it goes.
