how to tell the year of an rb26dett
RB
Car: 93 240sx
i am planning on picking up an rb26 front clip from venus but would like to know the year before i buy so i know if it has the crank collar problem i do know its an r32 but beyond that how do i tell what year the engine is
thanks
RBMonster
any RB26 up through 94 has (or could have ) the faulty collar. Jun makes a new collar for $120ish.
integra7
Car: 1995 Nissan 240sx
Like RBMonster said, the crank collar issue can occur on R32 or R33 motors. It just depends. There is no way to look at the motor and tell if you will have the issue or not. The only way to find out is to remove the oil pump and take a look at the snout of the crankshaft itself.
Also, that JUN collar is not a simple bolt on solution. If you choose to fix the issue, you will basically be rebuilding the bottom end.
