how to tell if u have a failing fpr?
black g50
Car: 1994 Q45 Black/Black--235/40/18's avh3100 xplode 12" and amp 160000miles.2001 rodeo 190000miles
Car still failed inspection for gas tank pressure.Smoked,soaped,tightened,still cant find leak anywhere.Pressure is around 30psi at idle.Gas smell is gone,idles and drives good.No codes.
black g50
On the big rust covered pipe,there is oil or gas on it.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Are you taking about a Fuel Pressure Regulator?
How long ago was the fuel pump and filter replaced?
The oil on the EGR pipe that leads to the exhaust manifold is from a leaking valve cover gasket.
black g50
Pump n filter were changed around Jan.Car just isn't building pressure in fuel tank.Other than that everything passed inspection.I only heard the hiss removing gas cap once since then.Car has been to 2 shops,and they confirm tank is good as well as lines.Now I'm leaning to FPR...
Infinitiguy19
Did the person who changed the pump use ALL the OEM nuts?
The Fuel Pressure Regulator (FPR) has never failed on one of these cars (G50). So I highly doubt that's the issue. The fuel pump just provides the volume and does not contribute to a pressure loss unless worn out.
Check to make sure there is no fuel on the top of the tank when driving all over the road with a 1/2-3/4 full tank. I know sounds bonkers but that's the only way I can think of it working.
Q451990
Ditto... I've never seen a regulator fail. Anything is fair game I guess, but I'd look to that last.
What about the whole charcoal canister system... can't remember what it's called at the moment.
Heath
black g50
Well gentall man,i have the first failure.It whistles dixey when car is running.Took off small vacume hose and no change in anything.
black g50
Haven't taken it off yet,is there some kinda cleaner I can run thru it?Or does it sound like a gasket problem?There is a strange whine coming from it.Has anyone used a adjustable fpr?
Q451990
I've never done anything with it except remove it and put it back during an injector swap. The whistle sounds like a bad diaphram, but just a guess...
Heath
black g50
Yea I never heard a noise come from it till new injectors put in.
black g50
Is it a simple pull it off pop one in job?
Q451990
After you pull the plenum, fuel rails, etc...
Heath
black g50
Not paying to pull plenum again,junk yard...
Q451990
I think I'd confirm the diagnosis a little more before you go to that extreme...
Heath
black g50
Ok,not sure if I'm even right about the area or part that's making the sound.It's coming from the rear near firewall at the two pie shaped things on back of engine(hat or flying saucer shaped things).Sounds like the one that sits right on the bigger metal pipe.I pulled the rubber vacume line off and it didn't have any air coming or going to it.Car has plenty off power no codes hand held found now faults.Followed all gas lines looking for this leak that's driving me nuts.Don't want to give up after spending all that money to get her running again but can't even get through inspection to enjoy her.
Q451990
Sounds more like the EGR valve and BPT. The fuel pump regulator is buried under the plenum.
You won't have vacuum at idle, the EGR is only open at cruise...
Maybe you could post a picture of the parts you're talking about?
Heath
