240kid wrote:ok, touch the negative to the o2 sensor body, and the positive to the connection.
it very well could be your MAF or cts or a number of things
is there anything else, like smoke or hard to start, or doesnt idle right, or anything like that?
Shew!! Than ks for responding. I wasn't getting much help lately.
Anyway, the car starts up VERY fast. I only have to let the car crank maybe 2 seconds and it starts right up.
Idle is rough. For the first minute of idling, the car wants to stall. I have to gently push on the gas pedal to keep the revs up. After that minute, it idles, but is still rough.
I am having a MAJOR bogging issue. The only way I can get the car going is by pushing the gas pedal lightly. If I push it too much, the car just bogs. I made a thread about this a few days ago.
If I disconnect the MAF connection while the car is running, it will stall out right then and there.
The hose coming out of the bottom of the BLP device had a hole in it and it had a lot of grit in it. I replaced the tube but it did not make a difference.
I have already replaced the dist. cap, rotor, plugs, and wires. O2 sensor is new too. Gas is new and 93 octane.
