auh wrote:I never try to go into 4lo when moving, but the last time I tried to shift into it while stopped I realized my car was in drive. I've followed the instructions in my manual. It just plaindoesn't work
Hey man, if in doubt if it is working, just take it into a shop or the dealer and have it checked...Best way if you are doubtful IMO
Also, when you shift to 4lo, does your steering feel a bit stiffer?
I would say try getting yourself a bit stuck in mud or sand or snow or something and shift it in 4lo and see if you can pull yourself out but that could be troublesome IF it is actually not working
How about your 4hi, is that having the same issue? When last did you change your fluids?
