How to Tap mini low-profile fuses?
mpbclutch33
Car: 2008 Altima Coupe 3.5L, 6-speed, Radiant Silver.
I have a 08' Altima Coupe and I have always ran a fuse tap to the interior fuse panel on my past cars. This car has low profile mini fuses. I went to every auto parts stores around here and Radio Shack and they all said "Good Luck".... So, How do you tap these type fuses on the newer cars. I guess they are all going to be this size in the next couple years. I am trying to run the signal wire for my system and wire the Fog lights up independently of the headlights.
MaximA32
The best way would probably be to find where you want to tap and splice into the wire behind the fuse block.
driftingmy240sx
Car: 1996 Nissan 240sx rb25det
easiest way to due it is get a regular mini fuse and tap into the block like you normally would. the low profile mini's can have mini fuses swapped into there place.
