ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Thu Aug 03, 2006 7:45 pm
you should try to remove the drain plug & empty the whole thing out/ that way, u won't overfill the unit & blow out the seals leaking out thru that boot you mention is going to leave you w/ a big ?= how much oil to i haveta top off?
if it's like my 89-91 transmission, the fill plug is a square male thingie sticking out on the driver side; I can put a 17mm open end wrench on it or you can use a bigger / adjustable wrench to try to get that fill plug off... that's the only way to check if there's enough GL4oil in the transmission!
well, if you're gonna do a total drain/refill w/ ~2.4 quarts of GL-4 gear oil, clean the drain plug end-magnet from the metal hair you'll see sticking @ the end of that thing...
reinstall w/ some thread sealer...
then,
click on me fo da instructions!
click on me for mo' instructions
then u can go search from there fo' mo' info if you can't see dose drawrings/ download the FSM on my sig link as well...
Modified by ricebike at 1:56 AM 8/4/2006
Modified by ricebike at 1:58 AM 8/4/2006
