how to take out gauge cluster
bigE
Car: Anything dealing in cars.
i need to take out my gauge cluster on my s13. can anyone help me
240dreams
Car: 240's
loosen the steering column bolts (4), take off the kick panel (like 5 bolts), pop off the trim piece around the steering wheel (2 screws top of the gauge cluster), take out the 4 screw that hold the gauge cluster in.
imdorkee
would this be the same for an s14?
extheflow
it's close..no need to mess with the kickpanel on s14. and the steering column sounds a little different.on S14 there's a loop below the column that has to come off first(2 bolts) then the column itself(2 bolts) then 2 screws in the trim around the cluster,then the screws that are actually in the cluster.
imdorkee
ah thanks for the info.
240dreams
Car: 240's
wups, didn't look at ur car.
