tramp_drift240 »
https://forums.nicoclub.com/tramp-drift240-u50915.html
Mon Oct 20, 2008 4:02 pm
for the rear, there are four bolts under rubber covers in the trunk floor, remove those. i think theyre 17s or something. then there are four or five 10mm nuts on each side inside the quarterpanel.
for the front bumper, you dont have to take anything else off. there are 5 or 6 nuts connecting the bumper to the fender on each side. get to them through the fender well in the front, its easier to do if you turn the wheels away from the side youre working on to make room for your arm and a ratchet, and perhaps 2 or 3 extensions.
then pop the hood and take off the bolts that run along the top of the bumper holding it to the radiator support things. youll see them.
and then there are a few plastic pop-in things on the bottom of the bumpers 'mouth opening' and a metal bracket thats bolted to the top of the 'mouth opening', also 10mm.
thats it.
