sstomek »
https://forums.nicoclub.com/sstomek-u31323.html
Sun Apr 29, 2007 11:30 am
actually nissan has a built in feature that not many people know about that would make taking out an engine a WHOLE lot easier. If you knock on the hood three times, but here is the tricky part. Its not knock....knock....knock but instead it has to be knock..(1 second)...knock......(3 seconds)......knock, kind of like a secret knock and when you open your hood back up, like magic, everything is disconnected and you could just take that baby out of there.
If that doesnt work i would suggest searching the forums or trying something like.
Disconnect all the wiring, the radiator hoses, AC stuff, unbolt from transmission, unbolt from motor mounts, and lift. Something along those lines.
