Xdisaster240sX »
https://forums.nicoclub.com/xdisaster240sx-u49626.html
Mon Sep 28, 2009 1:42 pm
Im not really sure where to put this write up so a Mod can move it to the proper place.
Tools:
I got my red needles off a 99 Sentra. Altima, Maxima, and other years of Sentras will work also.
Time: 1 to 2 hours
The first thing you need to do is remove the 5 screws on the bottom of the dash panel. There will be 2 12mm bolts holding your steering column up. Unscrew those and push your column down.
Now. Pull out your switches and unplug them. Be careful with the dimmer switch. It brakes easy. You could also unscrew the 2 screws on the top of the bezel then unplug the switches that way.. After you remove the bezel there will be 3 screws holding the gauge pod on. Remove those and unplug the wires from the back.
Once you have the cluster out, you will see tabs holding it together. Push the second row of tabs out and this will remove the clear plastic and the black face plate around the gauges.Use you flat head screw driver, Pliers or something small to pull the needles off. Its ok if the metal pin comes with it.
Push you new needles in and make sure their in the same position you pulled them out. Once replaced put everything back together and enjoy.
Here a night time picture.
Modified by Xdisaster240sX at 6:00 PM 9/28/2009
