how to swap gauge face on 89 MAXIMA
89turbomaxima
Car: 1989 nissan maxima
on my maxima the speedO has went bad and i have the se with white face gauges and i would like to keep them all maximas i have found have had the black one and i was wondering how i would swap the faces and one more thing i have 300k+ on the car how can i roll up the mileage on the new or can i ever do that. neeed help
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
You can't change the mileage. Swapping the cluster (I'm guessing that's what you're asking about) should be quite simple. Go HERE, locate your FSM, then go to the interior section.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
You could theoretically disassemble the cluster and change the odometer, but it's pointless and not legal (even to correct it to be accurate). Just record the milage off the old cluster and the milage on the new cluster at the time of the swap and keep it with your registration records.
Swapping clusters is very simple and the SE cluster works in the GXE with no issues. Just keep in mind that the SE has a higher redline than the GXE, so the gauge won't reflect real redline anymore.
Kountz430
Car: 1993 Infiniti J30, 1994 Maxima Gxe,1990 Maxima Se
he can swap out the odometer theres a couple of phillips head screws that hold the odometer in.I had to swap out the cluster on my 90. i played with the odometer from the cluster i got from the j\y you cant budge it. but yes he can keep his current mileage
