Great write up but I must say that I second this motion. The grommet is there for a reason, to keep any moisture out of the car. When you run it through the side of the grommet like that you are breaking that seal thus allowing moisture in.auditech10 wrote:I would strongly recommend that you run your power wire THROUGH the grommet and NOT between it and the fire wall as you have shown in picture 5.
Thanks for the soundgate product number.I do not get any turn-on pop or thump.removing the panels is not going to help get any more bass from the trunk into the car. it's sealed-up pretty tight back there. removing the factory pancake sub is the only way (unless you are brave enough to start cutting-up your rear deck, which I DO NOT recommend).nuge wrote:It is the SOUNDGATE LOCB2.
I am also getting a "turn on" pop. Did you get this?
I tried removing the cover in front of the gas tank, but it did not make any signifcant difference in the amount of bass.
,nuge wrote:I do not think removing the stock sub would help with getting the sound inside. The carpet panels in the truck would need to be removed or cut.
The stock sub is not even a standard 1o inch. It is almost impossible to find a replacement.
