How to stiffin up the clutch?
dbhittin
i searched for "clutch" and found nothing. I was told there is a way to stiffin the clutch up a bit. Right now, my clutch feels loose and its easy to push down, but it doesn't slip at all. I have clutch fluid in it and i shift fine, but the pedal is just loose. Is there away to adjust this and is it something i can do in a little bit of time. Thanks
912.0turbo
http://www.zeroyon.com There is an article there on how to do it but be careful and follow the guys instructions and warnings carefully!I've never done it but may try it one day(Maybe).
knowleqe
there is the clutch adjustment screw that you turn to shorten the clutch heights. also there is a steel braided clutch line kit that bypasses the factory clutch dampener box. it makes the clutch feel alot harder compared to stock.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
isn't there a spring somewhere by the pedal? could that maybe help stiffen it up?
knowleqe
there is a clutch adjustment screw at the top of the clutch
