Thanks cursed, that should help. And by CAS you mean what?CursedGTR wrote:Your CAS will look newer and will be black plastic looking instead of the traditional bare aluminum one with the little black dot in the middle. It will also have VVTi or whatever Nissan calls it. Everything else is pretty much traditional RB26DETT. The Valave covers should be Coca Cola Red if they are stock color and the Turbines are ball bearing. That is all I can remember for now.
I sourced it myself. Been looking for almost a year now. Funny thing is, I looked for so long, but then I sourced 3 at once.noodl35 wrote:if you dont mind me asking, where did you get the r34 rb26dett from?
I was under the impression they had VVTi, or whatever nissan calls it. But I will know soon, this will be the first R34 RB26 I have dealt with. Can't wait!sparksta wrote:I'm pretty sure they didnt come with VVTi either, but HKS does make a vvti system for the 26... so maybe thats what you are thinking
No it's VTC or CVT not VVL. Nissan NEO VVL is basically the same as Vtec.Kansei240sx wrote:Its VVL or CVT , and it does not work the same way DOHC Vtec works. They are different. It actually works more like SOHC vtec. without the lift.
