How to size Tial wastegates?
veovius
Car: Black '95 240sx
I keep hearing of 38mm, 41mm, etc wastegates from Tial. How do you figure out which sizes you need? How do you decide on a wastegate at all?
frsh13
Car: 1991 240sx coupe
Depends on the type of manifold and amount of boost you will be running. For most setups I would say the TIAL 38mm wastegate is one of the best options. You also need to decide what strength boost spring to gate in the wastegate.
nismofly
Car: 89 Nissan 240SX Hatch
most setups use a 38 yeah
for the corresponding spring pressures, at tials website you go to the size your looking for, and theres a pdf with all the color-pressure ratings
veovius
thanks, one more piece of info to file away
