How to shave off Front License Plate and General Plastic Repair
R6_240sx
Car: 1997 240SX LE, 2004 YZF-R6, 1980 Celica GT
OverviewEver wanted to shave of that front license plate on your urethane bumper but didn’t know how? Well, now you will after reading this write-up! Not only that, but learning the fundamentals of how to repair plastic parts in general.
First things first, NEVER EVER F*CKING USE BONDO/FIBERGLASS RESIN ON PLASTIC. I see people doing this waaaay too much on here. If you don’t know why then you have some researching to do. Not only that, but Bondo is a brand of Body Putty and it F*CKING SUCKS. You shouldn’t even use that for what it’s meant for anyway. Go to your local paint jobber and buy some real sh*t.
The basics of what we’re going to do here are:1. Shave the front bumper down.2. Shaving will create holes through the bumper and will also weaken its structure, so we need to reinforce it in the back side.3. Next, we’ll use plastic filler to fill in the holes, both front and back side of bumper.4. Lastly, we’ll use a plastic finishing filler to give us that nice smooth surface and hopefully it’ll look OEM when it’s all done.
Sounds pretty easy right? Well, the saying “Easier said than done” applies here. It’s pretty messy and laborious. It makes you wonder why someone hasn’t made a plastic mold of the S14 JDM Bumpers along with the S13 Kouki Bumpers w/o a front license plate. I bet those would sell like hot cakes! Then again, maybe not.
------------------------------------------------------------VideosOkay, if for some reason you’re still reading, that means you really want to learn how to do this. So let’s get more in-depth. Here are some good videos to watch made by the companies who sell these products. They’re mainly videos of how to repair holes in your bumper, but it can be applied to what we’re doing because we’re technically doing the same thing.
Evercoat (MAXIM™ Two-Sided Bumper Repair Video)Frame & Body Repair US 3M (Video - Plastic Front Side/Back Side Repair)
-------------------------------------------------------Alternative ProductsOur main product here is going to be our plastic filler. There are many products to choose from, but I only recommend Lord Fusor, Maxim (Evercoat), Duramix (3M), and SEM. I’m going to use Lord Fusor for personal preference, but I’ll post the other ones on here so you can take a look at it and decide for yourself which one is best for you.
3MDurami Semi-Rigid Plastic Repair 04240Applicator Gun, Automix Dispenser 08117Reinforcement Patch 04904Plastic Adhesion Promoter (Forgot part number)
EvercoatSemi-Rigid Epoxy Adhesive, 891Maxim Urethane Adhesive (887 Fast, 885 Medium, 891)Multi-Purpose Repair Panels, 828Plastic Adhesion Promoter, 883
SEMFlexible SEM-Weld, 39708Plastic Repair Reinforcing Tape, 7006Flexible Polyester Putty, 39458Flexible Polyester Glaze 39482--------------------------------------------------------------
Lots of stuff to look at huh? They pretty much do all the same thing, it just comes down to price and brand loyalty. Now let’s get to buying all the s*** we need so we don’t have one of those, “F*CK I FORGOT SOMETHING!” moments. Here’s the Bill of Materials I used:Rotary Tool (Dremel)
Grinding Bit & Cutting Wheel
Got sandpaper? LOL. You'll need (80, 100, 220 grit), don't forget to get some for DA Sander also if you're using.
Block Sander
Reinforcement Mesh-Now I know I said earlier not to use Fiberglass resin, but this is different from Fiberglass. All the reinforcement does is give the plastic filler some “structure”. Similar to how the fiber strands in Duct Tape makes it much more stronger. If you can understand this concept then you’re doing great. You can get Tiger Kitten and Fiberglass Mesh at Wal-Mart or your local paint jobber. But the cheapest route is those Fiberglass Screens they make for the screen doors to keep bugs out, you can get this at Home Depot. Lastly, you can stick to one product and get Lord Fusor Bumper Reinforcing Mesh 700
Lord Fusor Extreme Bumper Repair Adhesive (Fast) 152Lord Fusor Plastic Surface Modifier 602EZ
Lord Fusor Plastic Finishing Adhesive (FAST) 114 or equivelent. I used Evercoat Poly-Flex because I had some left over.
Putty Knife
Waterborne Wax and Grease Remover (Local Lord Fusor Supplier should carry this, make sure it's WATERBORNE not Solvent based.) I already have Southern Polyurethane's W&G Remover so I'm going to use this. Masking TapeRagsSoapLint Free RagsDust MaskEye Protection
Optional:Heat GunAir Compressor (Filtered)DA Sander
Nearest Lord Fusor supplier:Where to BuyIf you're in the SoCal area, I recommend Keystone Automotive in Ontario. They'll hook you up!
Steps1. Clean the area down with soap, both front and backside. FYI: Back is probably going to be real dirty.2. Spray the area with the Wax and Grease Remover, let it sit for a little bit to rise up all the dirt and grease and then wipe off with a lint free rag. You can use your FILTERED air compressor and blow it dry.3. Sand down the license plate area to bare plastic as much as you can. I recommend using the 100 grit for this. Not necessary to sand down the WHOLE THING, but make sure you have sanded down a decent amount of surface area. My pictures with the filler feather edged should give you an idea of how much to sand. 4. Take your rotary tool with the grinding bit and start grinding the front side of that sucker down. Try getting it as flush as possible, don’t worry if you start getting holes on the edges, this is going to happen regardless. Just don’t go to crazy on the grinding and keep it at a low RPM.See how it's bulging out a little? Still got more grinding to do! Ignore my hood... Much better!
5. Put the cutting wheel on and chop off that center circle. This step to some might not be necessary, but I did it because it’s a POS to sand down in the 3rd step which means poor adhesion when it comes to using the filler and the depth of the bore freaks me out thinking I have to fill that all in with plastic filler. Too thick of a plastic filler is a nono in my book.Those little tabs are hard to sand, just try the best you can.
Don't forget the back side!
6. The parts you just grinded down now should be melted plastic. This is no good when it comes to adhesion. Scuff up the whole license plate area with your 80 grit. Try to sand down as much melted plastic as you can, so the whole area looks uniform. This way you’ll get good adhesion.7. Now start cutting up your reinforcement mesh. You should have 5 total (Top L, Top R, Middle Circle, Bottom L, R). 8. Clean and wipe the area with W&G Remover.9. Wait 30 minutes so the W&G Remover fully dries, take your air compressor blow off the area to get rid of any dust and spray the whole area with Lord Fusor 602EZ. Wait a couple minutes.10. Take the masking tape and mask off the front areas with holes. Only press the tape down AROUND the hole leaving some space so when you fill it in from the back side it should seep through the hole into the front. I know this sounds confusing, but watch the 3M video I posted above to understand what is going on. Now wait a couple more minutes (10 minutes total from the end of step 9)It's hard to see in the pics, but you can tell what I'm talking about in the bottom left corner.
11. While you’re waiting, start mixing up the Lord Fusor 152, but only make enough for 1 of the 5 sections. This s*** cures FAST. (READ THE TECH SHEET THAT CAME WITH IT FOR DRY TIMES AND BASIC INSTRUCTIONS)12. Take the reinforcement mesh and place it on the back side and spread the 152 on it. It’s ok to be liberal with the 152.
13. Now take off the tape on the front side of only the section you used the putty on. If you did this correctly it should a good enough blob so you can take your putty knife and spread it across the hole.14. Repeat steps 12-13 to each section until it is all done.
15. Hopefully you did steps 12-13 PERFECTLY you can go straight to Step 19, but if you’re like me and you didn’t you have some extra work to do.16. If you have a heat gun use it to dry the 152 on the front side. If you don’t have one you’ll have to wait awhile… Once it’s cured, take your 80 grit and scuff up the 152 on the front side. 17. Repeat steps 8-9 on the front side only.18. Mix up a pretty big batch of 152 and lay it across the front side. Make sure to featheredge!!
19. Take your heat gun and dry up the 152.20. Once it’s dry, scuff it up with the 100 grit (Evercoat Poly-Flex says 220, but IMO that doesn’t give it enough “bite”). Take your block sander and try to get it as uniform as you can. It doesn’t have to be perfect, the finesse is in Step 23.Needs more sanding.Good enough.
21. Repeat steps 8-9 on the front side only.22. Mix up your Evercoat Poly-Flex or equivalent and spread it across the front side of the bumper with your putty knife. DON’T FORGET TO FEATHEREDGE! Some of you are asking why can't we just use the 152? Well technically you can, but I can guarantee that your arms will be sore from all the sanding. Hey at least you'll get a work out. But yeah, it's a waste of time trying to get a smooth finish with it, impossible if you ask me. Spend the extra cash to buy some plastic finishing putty. Wet.
23. Wait for it to dry (Read instructions for dry times). Now take your block sander with the 100 grit and get it as uniform as possible and then finish sanding with the 220 grit. Needs more sanding.Ohhhhh yeaaaa.
24. Wait a day, let everything full cure. There will be some shrinkage, hopefully you don't get any solvent pop-ups (meaning you didn't wait long enough to let the W&G dry. From here you can repeat steps 21-23 if you still aren't satisfied. But if are you happy with it... Now it’s ready for paint! Don’t forget to use a Plastic Adhesion Promoter if you paint it yourself!!!-----------------------------------------------If you're anal, you can go clean up the backside and make it look all pretty. I’m usually the type to do stuff like this, but this time I didn’t because I’m really tired and instead I decided to do this write-up to help out the community. Hope this helps. Feel free to critique on how this write-up can be improved. I better not f*cking hear someone say they used Bondo or Fiberglass resin on a plastic part and it hasn’t cracked yet. I don’t give a sh*t, it’s bad practice, and it’s a disgrace to anyone that does real bodywork.
Cheers.
S13Joe
Car: 92 Coupe
Great write up!! I'm putting this in my favorites for when I do a little secret work... yes surprises.
pedobear-lovin
Car: S14 KOUKI
ill bring u a bumper and u do it for me! how much? :D
awesome write up, bookmarked for sureeee
EnjoiNismo
Car: 93 240sx
Great write up!Wish it were painted
R6_240sx
pedobear-lovin wrote:ill bring u a bumper and u do it for me! how much? :D
Are you serious? You're all the way out in WA. The price of shipping a bumper would be out the roof!
EnjoiNismo wrote:Great write up!Wish it were painted
Should be done this week!
Sneek peak:Try and guess the color, hehe.
gregfarz78
Car: 04 Honda S2000
97 Nissan Hardbody King Cab 4x4
09 Nissan Altima Coupe 3.5L
Great write up I was just talking to a friend about this a few weeks ago wondering how you correctly fill a plastic bumper...now I know
BTW I'd love to see pics of a s13 silvia shaved bumper, thats one thing I hate the license plate holes in the front bumper
Modified by gregfarz78 at 6:37 PM 3/24/2009
