markinct »
https://forums.nicoclub.com/markinct-u132451.html
Mon Nov 09, 2009 10:23 am
Thanks ever[QUOTE=sg77]To expand on what kamiguy said, when you have the headlights on AUTO, there's a delay which you can configure before the lights turn off. The manual page 2-33 says:
"You can keep the headlights on for up to 180seconds after you push the ignition switch toOFF and open any door then close all the doors.You can adjust the period of the automaticheadlights off delay from 0 seconds (OFF) to 180seconds. The factory default setting is 45 seconds.For automatic headlights off delay setting, see"Auto Headlights Off Delay" in the "4. Monitor,climate, audio, phone and voice recognitionsystems" section."
Then on page 4-17 it shows that under Settings > Comfort & Conv. you can configure it:
"Auto Headlights Off Delay (if so equipped) :Choose the duration of the automatic headlightoff timer from 0, 30, 45, 60, 90, 120, 150 and180 second periods."
[/QUOTEThanks ever]yone ... appreciate it. But in my QX4,my lights did not have to be on AUto position to turn off. I never run my headlights on auto, Is there a way to do this withouty lightd bring on AUTO? Thanks
