how to set a home address on 03 M45 GPS?
Ryan Heo
Car: 1996 Infiniti I30
Hi.
I just fixed my GPS. It wasn't able to change "State".
Anyway I would like to remove the previous owner's home address. How to do it?
I have an owner's manual but it says that the seperate navi manual is needed.
Thanks.
candymanfb
Car: 2004 M45 - Every possible option on an M!
Press the "Setting" button, then chose the navigation option and you should see "edit address book".
I'm going off the navigation manual from my 2004 M45.
I hope this helps.
candymanfb
BTW ... not to be paranoid, but I have never set my actual home address on any navigation.
I usually set a business or an intersection close by that I know very well. I did this for my wife also.
Ryan Heo
I just found out what the problem was. It has checked a "short menu" option. Once the option was unchecked, I was able to edit the address. Anyway the map is really sucks compare with a $70 garmin nuvi. Does anyone have newer map? How is it?
Thanks.
