MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Fri Jan 22, 2010 1:45 am
Yeah, you just need to find the registry entry for CS4 and it'll contain the key. If you're familiar with browsing registry entries you should be able to just find it manually. Go Start>Run and type "regedit" to open the registry editor. BE CAREFUL not to delete or edit anything, or you could screw things up in a very bad way.The key you're looking for will probably be somewhere like [HKEY_LOCAL_MACHINE]\SOFTWARE\Adobe\(then one or two more folders/levels) and there will probably be an entry in there called ProductCode which will be your product key. If you can't find it manually, try the software Paul posted.
And yes, Windows Easy Transfer is awesome. You can use it to back up program settings and even your media library if you want (though it'll be a big file and will take a while to archive and unarchive). I used it to transfer my itunes library and entire "my documents" contents plus gamesaves to a FRESH install of Win7. You'll have to download it (free) for Vista but it's built into Win7.If you have multiple hard drives (physical, not just partitions) on your computer, or an external hard drive, I highly suggest backing up as much as possible to the secondary (non-windows, not being formatted) drive using Easy Transfer. It'll be a huge file but will still speed things up A LOT and once windows is installed you'll be able to just tell it to restore those items and you'll be golden. In fact it simplifies things so much I'd even suggest buying a cheap external hard drive for this alone if you don't have a secondary hard drive to use.
