locoluna825 wrote:
I also used the Energy Suspension subframe bushings and i love them but i didnt use the s13 stackable ones for my s13 i used the s14 and about 4 washers stacked ontop of the stock washer to hold them in.
BTW, Whats exaclty is the advantage of using a different ball joint. How come you just didnt replace them with s13 ball joints? Are they more expensive? Do the B12 Ball joints they perform better?
those are s14 bushings in the pic. i didnt need any washers, but i cut the metal insert shorter.
carps13guy wrote:i believe you torque the castle nut while the full weight of the car is resting on it. & wc are the b12 sentra ball joints taller and act almost like a roll center kit? any info is appreciated
yes torque them with the car on the ground. idk if they really act like a roll center kit. the b12s are a little taller but not by a lot
