mpoyner »
https://forums.nicoclub.com/mpoyner-u8903.html
Wed Jul 30, 2003 6:32 am
Guys, got a few things together over the weekend to start the slow process of updating all the fluids, main problem areas, etc. I will be doing things weekly, instead of all at once, because of cash flow.
First of all, the Traction Control was unplugged under the hood, for some reason. I said "what's this wire that's unplugged?", plugged it in, fired 'er up and the slip and TCS lights went off. It seems to work perfect.
Now, on to my invariable newby questions :rolleyes :
1. should I leave the TCS on all the time? If so, what are instances where it should be turned off? I've never had this on a vehicle before. Also, this only affects the rear wheels, correct?
2. How in the world do you get your arm into get the oil filter off? Is there something in the way that can be easily disconnected? I could get my fingers on it, but not with enough leverage to remove it.
3. Anybody created an online guide, forum thread detailing how to install a transmission cooler?
Thanks,Matt
