jltibbs »
https://forums.nicoclub.com/jltibbs-u32412.html
Thu Aug 16, 2007 2:08 pm
After you get the long bolts, you will need to mount them and see where to drill in the housing for the bolts to come through. You really want to be exact on where these holses are. We have to put a bolt and washers on the other side for proper aiming. Once you get the holes drilled, it's time for a test fit.
I painted the trim ring to match the car since i was not using bezels.
If they match up well, mount them. Get them mounted into the HLs, and before you put the glass back on, install the lights on the car, and aim them. This is the hardest parts. you have to utilize the bolts sticking out of the back of the housing to adjust the up, down, left, & right. Trust me when i say DO THIS TO THE BEST OF YOUR ABILITY. If you aim these wrong, you will get flashed constantly, or will have no projection on the road.
