I recently replaced both front wheel bearings and the right-side hub. During the process, we briefly disconnected the ABS sensors with the ignition in the on position. As you probably know, this triggered the ABS, Traction Control, and Limited Slip bulbs on the dash. I disconnected the negative battery cable for several hours, but the lights are still on. My local Infiniti dealer claims these are "hard" codes and cannot be cleared by disconnecting the battery.
I have found instructions for resetting the ECU on 1999 and earlier models, as well as, the 2002 and later (drive-by-wire) models. I don't want to pay the dealer $80 for 5 minutes worth of work (call it stupid pride), but also I don't want my wife driving the car in wet weather without ABS and TCS.
Any ideas for resetting the ECU on a 2001 I30 will be greatly appreciated.
Modified by mrI30T at 7:06 AM 6/15/2005
