elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Dec 10, 2005 11:10 am
Close Danny...
Take out that carpet thing, adn then remove the 2 screws... Then take the main harness off, loosen with a 10mm socket.. Then you can take the ECU out and then plug it back in (using 10mm socket)..
Then simply turn the screw all the way one way, and then the other way.. then you can read the codes... Once you do that... turn the screw the one way and then back the other way, and it will clear the codes.
