how to replace the oil pan and the gasket
jlagesej30y32
Car: 1993 J30 Y32 green 4 door
JNKAY21D8PMO29807
Hi I took my J30 y32 series infiniti car into a local infiniti dealer and they stated that I need to replace the oil pan and a gasket because its leaking I have the tools and i know where it is located under the car and yes its leaking. and some thing else is leaking as well thats next to it.
Now i have never replace one of these before i do know alote about the doors panels removeal and lighting but not under the car. can anyone please help.
And does anyone know about how long it could take to do this job. and just to be sure that i do have all the correct tools needed to do the job what tools are needed and it could be help ful if anyone knows how to remove the drive stick i have to replace the green light can see when you go to shift the car at night. thanks.
new member here just found this form online a web search its sounds so kool and helps to save money and time thanks for who ever thought of the idea and yes ill post some how to dos as well. about taking apart or removeal of car seats and the passenjer side door mirorr and the doors trim covers to get to the window switches. and more.
yodawill2000
Car: 94 Infiniti J30
Welcome to Nico.
Sad to say removing the Oil pan is a Beast on the J's.
See the link below to see what your up against.
post5896355.html?hilit=oil%20pan#p5896355
jlagesej30y32
JNKAY21D8PMO29807
I did view and got nothing on how to take it off. I am taking it off of another j30 car in the yard but dont know how do you happen to have the service manual ? I have a copy of one but cant seem to find it anywhere on how to remove it.
What about the light out in the shifter gear to put car into park and drive how do you remove it?
And my radio does not work its werrid but i can here a pulling scraping noise from the back right side of my car from the antenna going up and it turns on i jusst replaced the antenna with a bran new one from the dealer.
jlagesej30y32
JNKAY21D8PMO29807
the car only has about 80,000 miles on it. dont want to get ride of it its in great condition
