How to replace starter - V6 AWD
Domnjess4
Car: 2012 Infiniti M37X
I'm replacing my starter on my 2012 m37x , and I was wondering what else do I have to remove to get it out? It's a very tight fit. Looks like it has to come out through wheel well. Do I have to remove axle and motor mount for it to come out?
1st35
Car: 2007 M35x 2000 Lexus RX300 1998 Toyota RAV4
Not sure if the M35 is the same as the M37, but this video for a 2006 model might help out:
https://www.youtube.com/watch?v=oHzGPgr5Bn0
BUT!!! I always disconnect the negative cable first! Some people disconnect both, but always disconnect the negative first.
Ilya
Moving to 2011+ forum section.
ibc
Car: Infiniti M56x
Have you found the factory service manual? It shows all removal & installation details.
Find it at https://www.nicoclub.com/service-manual ... 12/STR.pdf
Domnjess4
Ty guys, I had to remove the right side lower control arm on drivers side so I could remove the bolt that holds motor mount raise engine a few inches to get axle out. The stater came right out through wheelwell. What a pain just to replace starter.
