According to my 09 FSM, that is the correct/only way to get to the spark plugs. You shouldn't have to replace the gasket unless it looks worn or damaged. If this is the first time opening the manifold you should be fine.blownb310 wrote:My question is, do I have to remove the intake manifold to replace the plugs on an '07 Sentra with an MR20DE?
Thanks for the reply and feedback. What size spark plug socket were you using? It was a spark plug socket and not a regular socket right?david_mejia9190 wrote:but when i go to changing them my spark plug socket doesnt fit.
OK let me get this straight:david_mejia9190 wrote:but when i try to take off the ones on the engine the socket doesnt fit all the wayit gets stuck like halfways through
I have read somewhere that the was the deal on some of the b14 sentras and it might be the case in my scenarioi will see if any rubber housing is blocking the way to the spark plugsThanks for the helpFaja wrote:Sometimes you have to use an extension on your ratchet to reach the spark plugAlso check the rubber housing inside the spark plug socket and make sure it can slip easily onto the top of the spark plug
