How to replace M35x interior bulbs with LED's??
40belowceo
Car: 06 M35X
Anyone know how to change interior bulbs to LED's or can provide me with some links with instructions? I clicked on the FAQ link and the instructions were erased or deleted.
Thanks,
avishal26
Car: 2014 Infiniti QX60 AWD White on Black Leather Premium + Drivers Assist + Theatre Package
2011 Chrysler 300C AWD Loaded
2006 Infiniti M35x (SOLD)
2008 Yamaha R1 Raven (SOLD)
Anyone? I'm interested too.. just bought some LEDs and waiting to install... don't want to break any plastic tabs :D
GQM45s
Car: 2008 Infiniti M45 Sport Tech Pkg, Advance Tech Pkg, Mobile Entertainment Pkg
its fairly easy, which ones are you guys going to do first?
40belowceo
Car: 06 M35X
Can someone tell me what bulbs to buy? I want to start with the top ceiling lights and then the doors inside and lining on the floor.
Minus (-)
Car: 08 M35x
http://www.sylvania.com/en-us/applicati ... 54&make=41
You can find those sizes on eBay. Some sellers have the whole bundle for the car with like 12 bulbs. What I do is buy single bulbs in bulk, it's basically the same price as the kit. A lot of the bulbs are interchangeable as well. The puddle lights(4),the trunk(2), and the DRL(2) are pretty much all the same bulb. You just have to get the correct amounts of LEDs on it.
Will update....
40belowceo
Car: 06 M35X
Minus (-) wrote:http://www.sylvania.com/en-us/applicati ... 54&make=41
Will update....
Thanks Minus. So you pretty much purchase these bulbs and replace them? Theres no adapters needed?
Thanks,
Minus (-)
Car: 08 M35x
Yes that's it....you an pretty much YouTube any car changing led bulbs....it's all the same...pop the cover off, unplug the wire,take old bulb out,put new bulb in...and if your not comfortable or is is your first time doing this, unplug the negative terminal on your battery to avoid blowing a fuse or 10.
GQM45s
This is my post from the other thread
GQM45s wrote:My setup:
Reverse lights - 15 Xenon White SMD LED - 921 bulb size
Turn Signals (front/rear) 68 Xenon White SMD LED - 7440 bulb size
Sidemakers - 1 Xenon White SMD LED - 921 bulb size
Fogs -6000k HID Conversion 35 Watt H11 bulb size
Front Headlights - 8000K D2S Bulbs
High Beams - 68 Xenon White SMD LED - 7440 bulb size (not very effective might change them out)
License Light - 10 Xenon White SMD LED - 921 bulb size
Door Lights - 15 Xenon White SMD LED - 921 bulb size
Parking Lights (bulbs sitting above High beams) - 21 Xenon White SMD LED - 921 Bulb size
Dome Light - 24 Xenon White SMD LED Panel with conversion kit to 3175 bulb size adapter
Rear Lights - 24 Xenon White SMD LED Panel with conversion kit to 3175 bulb size adapter
Vanity Lights - 3 Xenon White SMD LED - 23 mm Festoon bulb
Puddle lights - 5 Xenon White LED pods
fat3oy
Car: 07 M35X, 06 350z, 06 RSX, 99 Dajiban
GQ u ever change out those highs? I was looking at the V3 Triton led headlight bulb
40belowceo
Car: 06 M35X
Can someone tell me what the courtesy lights are? Are those the side door lights? Also, what are the lights for the two front seats that light up with the logo?
GQM45s
fat3oy wrote:GQ u ever change out those highs? I was looking at the V3 Triton led headlight bulb
I haven't yet, i been looking around and searching for new bulbs still
Larz
Car: 2019 Q70-L RWD
40belowceo wrote:Can someone tell me what the courtesy lights are? Are those the side door lights? Also, what are the lights for the two front seats that light up with the logo?
The courtesy lamps inside the bottom of the doors are 921. The kick plates with the logo illuminated are a sealed unit and far as I am aware, nobody on here has attempted them. It's much more complicated than changing a bulb.
40belowceo
Car: 06 M35X
Thanks Larz. The former owner of my M changed the kick plates from infinit to "FUGA" so I know it is possible. Would suck to have every other light LED and the Kick plates regular.
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
Larz wrote:The kick plates with the logo illuminated are a sealed unit and far as I am aware, nobody on here has attempted them. It's much more complicated than changing a bulb.
Dean has taken the kick plates apart - see 2/3 of the way down on this post: post6532444.html#p6532444
Not sure if he has attempted to change out the LED to another color.
enigmazing
Car: 2007 Infiniti M35 Sport
GQM45s wrote:This is my post from the other thread
Hey where did you grab the License lights from?
GQM45s
got a bunch off ebay for dirt cheap
40belowceo
Car: 06 M35X
Anyone know how to remove the front side fender markers to replace the bulb? I was trying to remove the driver side one and I ended up snapping the plastic top off and had to crazy glue it back.
GQM45s
you have to pop the lens off and glue it back together with silicon from my experience with the 06/07 thats the easiest way to get rid of the orange plastic inside the side markers. Same with the 08+ models. Have to be a bit more careful not to crack the lens but less time consuming breaking out the orange plastic
the1stTree
Car: 2009 M35 S
Technology Package
GQ,
Do have pics of under side of puddle light install? They look awesome!!! Nice job.
Tree
GQM45s
the1stTree wrote:GQ,
Tree
thanks man!, what kind of pics are you looking for? like how to install them? I think there is a link in the DIY thread if you are looking for that
the1stTree
Car: 2009 M35 S
Technology Package
Looking at how far from the edge of underbody you placed the lights for that beam placement. Which brand of lights?
Thanks
GQM45s
the1stTree wrote:Looking at how far from the edge of underbody you placed the lights for that beam placement. Which brand of lights?
Thanks
here is a pic of me putting the light in after i drilled a hole in my side skirts, its about 1 and a half inches from the outer edge in
the1stTree
Car: 2009 M35 S
Technology Package
GQ,
Thanks! I appreciate the details.
40belowceo
Car: 06 M35X
Hi All, So I changed just about every light to LED except 3. The maplights from the visors up top, the parking lights and the reverse lights. Anyone know what bulbs are for the parking lights and map lights? I believe the reverse are 921 correct? How hard is it to remove the head/tail lights and replace these bulbs?
Thanks in advance,
the1stTree
Car: 2009 M35 S
Technology Package
40belowceo wrote:Hi All, So I changed just about every light to LED except 3. The maplights from the visors up top, the parking lights and the reverse lights. Anyone know what bulbs are for the parking lights and map lights? I believe the reverse are 921 correct? How hard is it to remove the head/tail lights and replace these bulbs?
Thanks in advance,
Here is the link for previous topic for all the lights including map light.
led-upgrade-project-dome-light-conversi ... p#p6529717
40belowceo
Car: 06 M35X
Thanks 1stTree!
Vvsm45
Car: 2006 M45 Sport
Is it ok to plug out the auto leveler out the headlight? My left head light was making noise so I plug it out and manually level my head light.
GQM45s
Thanks in advance,
My setup:
