QR25DE posted a step by step list of how to do this before but I'm going to include some pictures. His how to can be found here:
how-to-info-reset-ecu-pull-codes-reset- ... eplacement
Anyhow here is what you need:
1. A key fob with a dying or dead battery!
2. A CR2032 battery (These can be found at Walmart, and more easily at Walgreens)
Okay so now let's start with the first step:
1. Remove the physical key from the fob by sliding this little tab over and pulling the key out.
2. Next locate the seam on the side of the fob and pry it apart carefully. I just used my thumbnails and started at the top corner where the physical key was removed. You may be able to use a small flathead screwdriver in the little slots on the sides, or a nail file or anything skinny.
3. Now note the position of the battery in the fob and be careful not to touch any of the sensitive circuitry on the other side of the fob. Simply swap out the batteries.
4. Finally, aline the two fob halves and pop it gently back together!
