How to replace idler pulley?
Ryan Heo
Car: 1996 Infiniti I30
Hi, I need to replace idler pulley to get rid of whistle noise from engine room. I bought a parts but I don't know how to do it even I have repair manual which is pdf file. I couldn't find... Could you guys help me?Thanks.
brianw
Car: 4-doors, 5-speeds...
Page MA-10 describes what you want. Probably just two bolts that hold it on, plus the bolt on the pulley itself.
GI-41 has the general bolt tightening torque, if you're worried about that.
http://www.motorvate.ca/mvp.php/500
That's for the alternator, but the procedure is similar...
acidjake75
Car: 05 DB Z
you can get an FSM free at PHATG20 dot com, gives you the instructions you need, also spend some cash and get Chiltons or the Haynes Manual - those help out alot for basic maintenance stuff like this.
I hope this helps some
Ryan Heo
I'm trying to firgure out now.I don't know the sign that is "N.m (kg-m ft-lb), (kg-m in-lb)"does it mean how much tight to bolt and nut?How do I know???Thanks.
maxhopper
Car: 02 Maxima SE 6spd
Yes, that is how hard to tighten a bolt.
nm=newton meters (metric)kg-m=kilogram meters (metric)ft-lb=foot poundsin-lb=inch pounds
Those numbers correspond to settings on a torque wrench.
Ryan Heo
I replaced the idler pulley and belt.It wasn't difficult.However I tried to replace another belt which is short one.I couldn't because I don't know how to loose the pulley.I read a manual but it doesn't give any ideas to me.I just gave up...
